David Brown 990 hydralics
weasle
05-18-2006 19:45:39
Hi, I just bought a 990 selectamatic with a loader. 3pt works good and loader goes up and down but won't lift much... Any ideas 'cause I'm fresh out!!!!
Hawkeye Gold
05-20-2006 08:34:45
 Re: David Brown 990 hydralics in reply to weasle, 05-18-2006 19:45:39
Make sure you have a clean hydralic filter--that will help some. But, I do not think that pump has a lot of power anyway.
jonjon
05-19-2006 12:08:26
Is this loader for this tractor or homemade.
weasle
05-19-2006 19:08:34
 Re: David Brown 990 hydralics in reply to jonjon, 05-19-2006 12:08:26
half and half... the loader itself is a factory loader, it originally had a trip bucket and has been changed to a hydralic bucket
meadova
05-21-2006 08:37:57
 Re: David Brown 990 hydralics in reply to weasle, 05-19-2006 19:08:34
Have a loader on my 990 and it has no problem with 1 ton bulk fertilizer bags. Do have a manual on it E-mail if I can help.
weasle
05-21-2006 22:43:35
 Re: David Brown 990 hydralics in reply to meadova, 05-21-2006 08:37:57
it's got a monster bucket on it so you would think it should lift pretty good... 3pt throws a big 'ol plow around like it's nobody's business and the rear remotes work perfectly too... would it cause problems if the return from the loader controls wasn't set up right?? my father-in-law has a 3800 and location of the return is the only difference. loader is the only problem and the pump screams a little louder when your tring to use it... pretty much out of ideas!!!
J. Irwin
09-17-2006 08:48:30
 Re: David Brown 990 hydralics in reply to weasle, 05-21-2006 22:43:35
Maybe cylinder is bent, have a ford with messed cylinder and it works but barely lifts.????
