Need help identifying a Case
Jim(UT)
11-10-1999 10:37:19
Hello there. I'm a guest from the Ford and N-boards. Trying to help a friend find a good loader tractor. Ran across a Case with a for sale sign on it and don't know a thing about them. Please help. On the hood side it says Case 430. On the dash there is a tag with a 440 stamped as the model number. Serial number is 8324155. Decal on the side says "draft-o-matic". Engine is 4 cyl gas and has a decal on the side of the valve cover that says "Model G148B". I assume that's the model number for the engine only? Trans has speeds 1-4 with R and S. I know what R is, but what is S? Slow? Stationary? Solidified? Also appears to be an aux tranny with 3 settings H, L & D. H & L make sense, but what is D? Any idea how old this is? There is a loader installed and looks factory but what do I know? Unit looks kinda rough: missing grille, missing headlight, dents, missing seat cushion. Battery access door has been removed and the opening enlarged via hacksaw...I assume to install larger battery. Was this originally a 6v? It's 12v now but still appears to have a generator rather than an alternator. Any help or guidance would be greatly appreciated. Owner was nowhere to be found so I don't know what he's asking.
Jerrie Lott
11-10-1999 16:32:57
 Re: Need help identifying a Case in reply to Jim(UT), 11-10-1999 10:37:19
The 430s were made in the 60s, I'm not sure when production was started but was ended in 1970. The engine is 148 cu in probably rated about 35 hp The "S" is the start position. They are handy little tractors, probably worth from a $1000 on up to $3000 or more depending on the condition.
