580 ck/b
emil selich
05-17-2006 08:19:38
Can I run anything other than hydraulic fluid (TCH) in the shuttle to help with the slugish performance?
Roger (Mi)
05-18-2006 04:38:58
 Re: 580B torque converter oil.. in reply to emil selich, 05-17-2006 08:19:38
TCH (Torque Converter Hydraulic) oil is the proper oil for the shuttle transmission. Using some other weight oil will NOT help. Check the filter in front of the radiator and the clutch pressures. If you continue to have problems, purchase the service manual from Case. It has excellent trouble shooting guides. While it's expensive, you'll save money in the long run.
