case 411b throttle carb linkage
travis angell
05-16-2006 11:08:46
Does anybody know if the lever from the carb should stick up or down? Mine sticks up and sounds like it might be backwards, it is a new carb and I didn't now how it hooked up. The linkage from the govenor is on top of the carb but I wonder if I should move the carb lever under so it hooks up under. The throttle lever on the dash is backwards at the moment, if I moved the carb lever under that should get the dash lever woring in the correct order. I also wonder if the govenor is operating properly because when I slowly move the throttle lever the govenor takes a hold and over reves the enine. can anyone help? thank you Travis Angell
Shovelman
05-16-2006 15:13:31
 Re: case 411b throttle carb linkage in reply to travis angell, 05-16-2006 11:08:46
Travis,
The lever on my 411-B carb points down.
If you are having trouble with the linkage, be sure to check the foot throttle linkage as well. I had some trouble with mine.
To adjust the governor linkage: Pull throttle full open. Disconnect to gov to carb rod, hold the carb lever full open and then adjust the rod length so it drops in to the hole in the lever.
Good luck,
Scott
Shovelman
05-16-2006 16:09:37
 Re: case 411b throttle carb linkage in reply to Shovelman, 05-16-2006 15:13:31
P.S.: I almost forgot. If the carb is equipped with a throttle stop pin, you want to adjust the rod so there is a slight gap (1/16 inch or less) between the arm and stop pin at full throttle.
Good luck,
Scott
