case 1030 comfortking
super gravely
05-15-2006 15:58:14
I need to know if there is a tick or some way to get the steering shaft off or the u joints off to take the gear box off
c hess
05-15-2006 18:17:36
 Re: case 1030 comfortking in reply to super gravely, 05-15-2006 15:58:14
Just a note for thought .If you are having trouble turning trouble may be 40 yr old u joints used on830-930-1030tractor that are suffering from lack of grease. Ihave used penetrating grease in aerosol can to free my 930 steering. Guess they can be taken apart an repacked but have not done so.Dont use them much any more.
c hess
05-15-2006 18:17:29
1030 brian
05-15-2006 17:15:49
The Ujoint at the gear box has a roll-pin in it on the gearbox end of the Ujoint. Drive out the pin and then drive the joint back to get your clearence. The shaft is also keyed along with the roll-pin. You also may have to take of the stearing shaft mount behind the oil filter to allow to shaft to move out of the way. Hope this helps!! Good luck
CNESLER
05-15-2006 17:12:41
Its been a while but the best I remember you pull the steering wheel and un bolt the plate on the column under the wheel. Then the u joint under the dash will pull off the shaft giving you enough slack to remove the rest of the shafts
Good Luck
CNESLER
