throttle case 411b
travis angell
05-15-2006 11:08:21
I have a case gas 411b case o matic. I just purchased it and the govenor was not hooked up on the new carb. I have hooked it up and when I start to idle the tractor up slowly the govenor grabs the linkage pulls the carb throttle wide open and I have to manually pull the govenor lever back down to an idle. I got a few pics from the cae internationl dealer and everything seems to be hooked up correctly. When I want to idle the tractor down I have to pull the throttle lever down. That is backwards from every other tractor I have ever run. Does anybody know if the lever is supposed to go up for increase speed or have I gotthe linkage messed up somewhere? Thank you Travis Angell
travis angell
05-16-2006 07:46:56
 Re: throttle case 411b in reply to travis angell, 05-15-2006 11:08:21
So the throttle rod from the govenor to the carb should be on the bottom side of the carb? Mine is currently on the top side of the carb. So all I need to do is turn the carb throttle arm lever 180 degrees so it is pointing down and the govenor linkage hooks to the bottom side? thanks for all the help. Travis
rongrong
05-15-2006 21:39:49
if there is a new carb maybe the plate where t he gov rod attatches is upside down or the throttle shaft is put in wrong, and you are pulling from the bottom not the top...
travis angell
05-18-2006 08:55:00
 Re: throttle case 411b in reply to rongrong, 05-15-2006 21:39:49
I switched the plate on the carb and it worked thank you. Travis Angell
travis angell
05-16-2006 11:12:19
So should the rod be on the bottom or the top my mine is currently on the top. The dash throttle lever is backwards so if I move that plate so I am pulling from the bottom it will reverse the dash throttle lever. (I think) thanks so much Travis Angell
dctom
05-15-2006 16:21:57
linkage is backward some place mine dont work that way could be undeer the tank
