ebay guages
Roger300
05-15-2006 08:58:17
Hi; There's a nice gauge cluster on ebay, #7617763026, not sure what differant tractors they fit, it's off of a 300 round nose but does it also fit the 300B etc, but I don't think it will fit the 430, 530, etc. because I believe they had a differant PTO speed. I'm sure it will fit in the housing but wouldn't be the correct gauge. Thanks for any information you may send me, Roger
Roger300
05-15-2006 17:10:47
 Re: ebay guages in reply to Roger300, 05-15-2006 08:58:17
Thanks Joe; Would you open your email so I could talk to you a little about that temperature gauge. I've pretty much been trying every thing but the right one I guess. I'm a little handy with that sort of thing, I found a way to reverse the tach. gauges by using one part out of the other one. Roger
Joe (Wa)
05-15-2006 17:36:06
 Re: ebay guages in reply to Roger300, 05-15-2006 17:10:47
Roger,
[email protected]
Joe
Joe (Wa)
05-15-2006 10:08:51
Yes, it is the same cluster on the 300b series with gas engine.
Joe
Joe (Wa)
05-15-2006 09:42:51
The tach sweep is opposite direction on later SW gauge clusters. The oil pressure gauge is 0 - 30 psi for gas engine, diesel is generally 0 - 75 psi.
The faulty temp gauge can be replaced with an older SW 2" 240 deg electric gauge movement using the face plate off this mechanical gauge if you are handy. I've done that on both my 300's, looks original.
Joe
