Case DC
Ron Taylor
05-14-2006 21:42:29
I just recently aquired a DC and the clutch won't release.I adjusted the linkage but still nothing.Is the clutch adjustable internally? It looks like it may be.Thanks for any info.
Ron Taylor
05-15-2006 20:19:11
 Re: Case DC in reply to Ron Taylor, 05-14-2006 21:42:29
Hey guys I appreciate your help,will give it a try
D boll
05-15-2006 09:53:42
I had one where one of the pivots for the fingers got rusted, split it to learn the hard way!
Camboted
05-15-2006 09:29:56
You've got a gummed up wet clutch, before you split it try dumping a gallon of kerosense or stoddar's solvent into the bellhousing, Let it soak for 10 minutes then turn the engine 180 degrees and soak another 10 minutes. Then chain it to a stout tree and put it in 4th gear. Start her up and push in the clutch and release several times. This may well break her loose. If not get a set of splitting rods and go to work. If it does work remember to change the oil. LOL!
