Parts for a David Brown 950
Jim Orr
11-09-1999 20:15:43
I need the small U shaped tube that fits on the bottom of the steering shaft. It is the tube that takes the small steel balls from the top to the bottom of the collar which is over the screw on the end of the steering shaft.
Please help
Thank You
Elmer Landman
11-10-1999 04:29:22
 Re: Parts for a David Brown 950 in reply to Jim Orr, 11-09-1999 20:15:43
I can get one for you, i may even have one in stock. Make sure your ball nut is not wore too bad. Where are you located. I'm in Ontario
