VAC serial no# help ????
VAC54
05-13-2006 17:08:01
my vac has a serial #vac51528 52 on tag on dash. there is a number on the block RT.side below the head that reads vac124-53588 this tractor was bought new by my uncle and has never been reparied whats up??.
Joe (Wa)
05-14-2006 00:21:56
 Re: VAC serial no# help ???? in reply to VAC54, 05-13-2006 17:08:01
The tractor serial nr is specific for model year, serial nr 5152852 is 1947.
The engine serial nr is also chronological but for a group of tractor model years. Engine serial nr vac124 + 5 digits is the factory engine for 1946 to mid 1949 VA tractors.
Engine serial nr vac124 53588 (vac124 is the engine series, 53588 is your block within that series) is chronologically correct for tractor serial nr 5152852.
Joe
Ron Green
05-15-2006 16:39:48
 Re: VAC serial no# help ???? in reply to Joe (Wa), 05-14-2006 00:21:56
Joe,
You I have a case tractor that has a # stamped just below the head by the oil filter,on the block VAB124-20146
Do you know what this tractor is.
I was told it is a 1948 Case, but thats all I know.
Can you help me
Joe (Wa)
05-15-2006 17:59:41
 Re: VAC serial no# help ???? in reply to Ron Green, 05-15-2006 16:39:48
VAB124 + 5 digits engine serial nr is for one of the VA series tractors. It is 124 cid, the "B" was replaced by the "C" engine that is the subject of this thread.
If your tractor has the original engine, I would guess the model year 1944 - 1946.
I lost most of my older Case literature when a tree took out the roof on my shop last Feb so I can't come up with any better info.
Joe
John Noname
05-13-2006 20:10:49
Not sure what you are asking? You have the serial number which would make it a 47 model. On the V series the only place the serial number showed was on the tag on the dash plate. All other numbers are part numbers.
scott6143
05-13-2006 18:22:06
I may be wrong but I belive the number on the engine block is the casting number for the engine and has nothing to do with the serial # of the tractor.
