SC ring gear
Travis Soppe
05-12-2006 10:38:26
I need badly a flywheel ring gear for a late model Case SC, I have checked places like A&I but they don't have. I can't really flip it over because the teeth are beveled on one side. Someone already did the 180 degree spin trick on it too. If you know where to find one I would really appreciate it thanks.
dsmoker
05-19-2006 13:54:50
 Re: SC ring gear in reply to Travis Soppe, 05-12-2006 10:38:26
Case part number is O5565AB. Still available.
Walt Davies
05-13-2006 08:27:46
A lot of people think that they can save money by fixing their old starters and generators but it has been my experiance that you just can't get the same results as a good rebuilt one. They do more than just polish the commutator and clean it out with solvent. They replace the brushes, turn down the commutator and clean out the webbing in it. They replace all worn parts with new like the gears and bendix if they have one. They replace or repair all wiring to new condition. They even paint the darn thing for you. All this for about $100 exchange I don't think you can beat that by doing it yourself. after all you want the starter to last as long as you do. don't you. Walt PS I would tell you where to get one like this but YT won't let me put the name up on the forumn any more. So if you want it you will have to e-mail me.
Travis Soppe
05-13-2006 08:48:09
 Re: SC ring gear in reply to Walt Davies, 05-13-2006 08:27:46
My starter is fine, just needs a new drive, which I have done many times, these old Delco starters and alternators are pretty easy to work on and to get parts for. Some of the drives are hard to get if they are odd, but places do have them. What I really need is the ring gear on the flywheel.
Walt Davies
05-13-2006 08:15:43
I had the same problem on my SI it would alway land in the same spot when stopped and the gears would not engage to start the engine. I would give the engine a little turn on the crank and then hit the starter. When I replaced the starter with a rebuilt one it worked OK after that. Walt
Bob KY
05-13-2006 07:35:05
I was worried about the bevel and the grooves leading into the notches between the teeth on my 43 SC ring gear but I flipped it anyway- so far it works fine without the bevel and grooves facing the starter- I used a file to make a bevel and used a torch to get it good and hot to put it on (but not red hot). That was about 6 months ago. Since then I have made 40-80 starts. It has never ground even once.
By the way- it was a bad starter drive that killed one side of my ring gear. You might check your starter out in case it was at fault in your case.
Just my 2 cents.
Travis Soppe
05-13-2006 08:45:17
 Re: SC ring gear in reply to Bob KY, 05-13-2006 07:35:05
Thanks, I might try that, I was going to use that as a last resort, but if you did it then I know it will work. I know the drive is bad, but it was new about a year ago, the ringear has been bad since I bought the tractor. Just got around to spliting it, I got a new starter drive ordered already, Thanks
Glenn F.
05-12-2006 17:07:42
I bought a new one aat Checker Auto Parts here in Green Bay, WI last spring. Price was $45-$50. Glenn
rd/oh
05-12-2006 16:17:12
I have a new ring gear for an SC I"ll take $55. plus shipping for it. Let me know Ron 419-759 3373
mike in mo
05-12-2006 11:13:56
try www.peepertractor.com he is a case guy and a parts dealer here in missouri.
