case 450 track dozer hydraulic problelm
Tom Benda
05-11-2006 20:35:41
i have a 1978 case 450 track loader with a definite settling problem. all six cylinders on my 4 in 1 bucket settle. I have been told that this could be a multitude of problems. A mechanics said that it could be the pressure releif valve or just warn out cylinders. none of the cylinders leak. the hardest to work around are the main lift cylinders. They seem to settle the fastest. any solutions?
Walt Davies
05-11-2006 22:39:27
 Re: case 450 track dozer hydraulic problelm in reply to Tom Benda, 05-11-2006 20:35:41
Rebuilt all of the cylinders I know that's not what you wanted to hear but there really isn't any short cuts here.
You can do them yourself if you have a large enough vise to hold them securly and the right tools to take them apart. Use a long rod with a slot in it to hold some fine emory cloth to polish the inside of the cylinder and replace all of the rubber parts. seals piston parts and any "O" rings. You should be able to get a kit for them that has everthing. Your next option is to send them out to a shop that rebuilds cylinders as their only busines not a side job. they will do a better job for less in the long run.
Walt
