There should be an engine number stamped on a tag under the starter on the right side of the engine block. Assuming it is original, that should get you a reference to go on. If it is not there, you can narrow it down a bit based on the configuration. Is it an eagle hitch, or draft-o-matic? Does it have a gauge cluster on the dash or individual gauges? I believe the last eagle hitch was made in mid-1963, and the gauge cluster was phased-out during 1965. The very early models (I believe the 1960 and early 1961 models) had disk-type brakes, verses the band brakes on the later models. There were at least 3 different power steering setups as well (approximately 1960 to 1962, 1963 to 1965, 1965 and later) that could help you narrow down the possibilities. It doesn�t appear there were many significant changes after mid-1965 (which would include the late 1965 through 1969 models). I had a similar challenge on my 430. Some genius torched a hole in the dash where the tag once was, and the engine had been replaced, so there was no way to determine an exact year. However, I was able to narrow it down to after mid-1963 and before mid-1965. Fortunately, my 530 has both tags, and is a late 1965 model. - Joe
