AXLE SEALS
JR(CASE38MAN)
05-11-2006 12:07:09
Working on a VC .the # on seal are 75260-H CR.. THE BOOK SAYS VT 2090..need new # please...thanks JR
Jim Yadon
05-11-2006 12:46:52
 Re: AXLE SEALS in reply to JR(CASE38MAN), 05-11-2006 12:07:09
Hello my name is Jim Yadon. The replacement seal number from Chicago Rawhide is: CR17557. The new seals are not the same. The new one's are half as thick. I have found that the old seals have damaged the axles so I buy 4 of the new seals and put two in backwards and then put two in the correct way. This still won't make sure the seals don't leak. But it has helped. By placing this way it places the seal in a different location than previous one was sitting on the axle. Hope this helps. Good luck
