vai rear end
mike in mo
05-10-2006 15:32:15
ok here my trouble i broke a bull gear dont ask how i dont know. but i found a rearend and tranny but i just want to change the rearend so. i pulled it apart cleaned it all up and started to put it back on well here is where it all went wrong i put it up on the studs and pushed it on as far as it will go and started the 4 nuts but i cant get it to go all the way on the nuts are loose but it wont slid up to the back of the tranny i tryed to pull it up with the nuts but that dont work. any ideas?
thanks mike in mo
Jerry W
05-11-2006 09:09:58
 Re: vai rear end in reply to mike in mo, 05-10-2006 15:32:15
Are the bull gears in the rear the same tooth count as what was removed. Early VA rears also have different bolt pattern than later.
Jerry
mike in mo
05-11-2006 09:14:37
 Re: vai rear end in reply to Jerry W, 05-11-2006 09:09:58
well all the old case guys around town said it was the same but i just found the the bull gears inb the vac are bigger than a vai so im going to change tranny and all.
Jerry W
05-11-2006 13:08:15
 Re: vai rear end in reply to mike in mo, 05-11-2006 09:14:37
How many teeth on the bull gear that you broke a tooth on. I have a couple of gears laying around I would sell. I think what you are doing is using VAC parts on a VAI and finding out that certain things are different.
Jerry
mike in mo
05-12-2006 11:10:58
 Re: vai rear end in reply to Jerry W, 05-11-2006 13:08:15
thanks for the offer jerry. but im going to change the tranny and rearend so i can slow it down some. its way to high geared for a loader tractor.
BLR
05-10-2006 21:57:51
Pull out the pto unit and try it. The pto shaft may not be aligned
mike in mo
05-11-2006 06:10:04
 Re: vai rear end in reply to BLR, 05-10-2006 21:57:51
no pto in it
