Adj. Wide Front...Long Shot
Glenn F.
05-10-2006 14:15:32
The adj. wide front on my SC CASE has a welded stopper on the right side. Anyone have a good casting for sale? Mine is nicely welded but I don't expect it's too strong as it's hard to get a strong weld on cast in such a spot. Thanks, Glenn F.
Bob Lenz
05-10-2006 18:47:41
 Re: Adj. Wide Front...Long Shot in reply to Glenn F., 05-10-2006 14:15:32
Glenn I just went thru the same thing with my SC awf. Its relatively easy to take a "bracket" from a narrow front SC (I purchased from Don L)there easy to come by, have a machinist cut "stem" of casting to proper length (it needs to be shorter) and then machine parts from your existing awf to fit. It sounds complicated but its not. Hope this helps. Bob Lenz
Glenn F.
05-10-2006 19:45:27
 Re: Adj. Wide Front...Long Shot in reply to Bob Lenz, 05-10-2006 18:47:41
Thank you for your reply, however I think we're talking about two different areas. I'm referring to the casting on the right side of the front end which the king pin goes through. These stoppers are notorious for breaking off. Glenn F.
