backhoe hydraulics
Ralph Sullender
05-10-2006 10:30:29
I have a 530 with CK loader and would like to mount a ditchwitch 140 backhoe with power beyond how should I hook up hydraulics ?
Ralph Sullender
05-13-2006 05:45:12
 Re: backhoe hydraulics in reply to Ralph Sullender, 05-10-2006 10:30:29
I do not have hoe attached the dithwitch hoe I have is plumbed with pressure in-return to tank-power beyond should I plug power beyond or pipe it to loader
Ralph
Roger (Mi)
05-14-2006 04:25:59
 Re: Do it right backhoe hydraulics in reply to Ralph Sullender, 05-13-2006 05:45:12
To do it right, you'll need the "Power Beyond" loader valve fitting that goes into the loader valve. Go to a Case dealer or salvage yard and get one. The "Power Beyond" fitting will be plumbed to the Ditch Witch. The return line from the Ditch Witch will need to TEE into the RETURN to sump line at the loader valve. The relief valve on the loader valve needs an unrestricted return to sump. If you have the outlet from the loader control valve going to the Ditch Witch, the loader relief valve will be RESTRICTED and will not work. With the "Power Beyond" fitting in the loader control valve, both the loader and the Ditch Witch will BOTH share the same relief valve in the loader valve. One note: If you remove the Ditch Witch and want to use just the loader, you'll need to connect the hydraulic "supply" and "return" lines that went to the Ditch Witch together.
Dennis/Ohio
05-18-2006 00:07:18
 Re: Do it right backhoe hydraulics in reply to Roger (Mi), 05-14-2006 04:25:59
I'll add one note. My 530 (not CK) has a relief valve on the hoe set at 1875psi & loader relief set at 1950psi. The hoe relief will open first when using the hoe. If relief valves aren't set correctly, the loader valve would be the only relief valve working.
Best, Dennis..... ...
Roger (Mi)
05-12-2006 04:03:43
 Re: Hydraulics power beyond... in reply to Ralph Sullender, 05-10-2006 10:30:29
If you have a backhoe mounted on the back, then you already have "power beyond". There is a fitting in the loader valve that diverts hydraulic oil to the backhoe. When a loader/backhoe has good pressure at the loader but weak pressure at the backhoe, usually the 0-rings in the power beyond fitting in the loader valve are blown. Connect the Ditch Witch to the same hydraulic circuit as would be for the backhoe.
