830 Case question
KRUSS
05-10-2006 06:37:20
A recent ongoing problem with my 830 Case (square fenders) Comfort King???? has been that the clutch pedal sticks. Mostly what it does is it doesn't return without a good solid smack with your heel. I have established that the problem is not in the actual clutch as the pedal still gives trouble with the control rod disconnected. Yesterday I removed the left brake drum cover (and brake components) which is the only way I can see to get at the clutch pivot. I got a bit of oil and grease on and helped a bit. What I need to know is what are the components that the clutch pivots on? Is it a bearing? Or brass bushing? Or pressed in rubber bushing? If I went to the effort of removing the clutch pedal entirely is it likely that I would be able to obtain the bushing/bearing in question? With the number of 30 series Cases around I don't think this is a new problem. Can someone give me the answer. Thanks and sorry for the long post.
TexasWren
05-11-2006 21:00:31
 Re: 830 Case question in reply to KRUSS, 05-10-2006 06:37:20
The pedal pivot is a needle bearing, and I was still able to get the bearing and seals from the dealer (haven"t put them in yet, but I have the opposite problem from you -- TOO much slop) You could try just pulling it apart, cleaning it and regreasing it, since CASE wanted something like $40 for the bearing and seals. If it doesn"t work, you aren"t any worse off than before.
mlm
05-10-2006 07:01:57
Had the same problem on a 930. Found the left bearing for the clutch cross shaft was dry. Removed the link lever from the cross shaft to get at the bearing. Was able to grease the bearing with a needle greaser.
c hess
05-10-2006 14:36:22
 Re: 830 Case question in reply to mlm, 05-10-2006 07:01:57
May just need to be taken off shaft an bearing surfaces cleaned an lubricated. Also does it have return spring on?
KRUSS
05-10-2006 15:55:30
 Re: 830 Case question in reply to c hess, 05-10-2006 14:36:22
Yes, I was thinking it may need to come off. It now has a new return spring.
