parting out a case 310
hilario fernand
05-08-2006 19:20:56
I am parting out a case 310 tractor. sheet metal is gone. cylinder head has a stuck valve. everything else is good. e-mail me if you need a part... i can send pictures of the part you need.
lucasd
05-10-2006 04:31:43
 Re: parting out a case 310 in reply to hilario fernandez, 05-08-2006 19:20:56
I am interested in the wheels, rims and hubs for the tractor, and also the guage cluster if you have it. Thanks.
Steve Rhoads
05-09-2006 06:36:11
I am looking for a front crankshaft pulley off of a 310 engine. The pulley I need has 4 tapped holes in the front face used to drive a front mounted hydraulic pump.
Thank you,
Steve
Hilario Fernandez
05-09-2006 08:31:56
 Re: parting out a case 310 in reply to Steve Rhoads, 05-09-2006 06:36:11
THIS TRACTOR HAS THE PULLEY BUT SOMEONE TACKED THE BOLT THAT HOLDS THE PULLEY TO THE CRANKSHAFT. I CAN SELL YOU THE CRANKSHAFT WITH THE PULLEY FOR A REASONABLE PRICE. OR IF YOU ONLY WANT THE PULLEY I CAN REMOVE IT. MAKE ME A REASONABLE OFFER. I JUST DECIDED TO PART THIS TRACTOR AND HAVE NO IDEA ABOUT THE PRICES. I WANT TO MAKE A PRICE LIST WITH PHOTOS AND POST IT ON THE INTERNET THIS WEEKEND SO THAT INTERESTED PEOPLE CAN HAVE A BETTER IDEA. IF INTERESTED I COULD POSSIBLY MAIL YOU SOME PHOTS OF THE PULLEY.
Steve Rhoads
05-12-2006 06:25:39
 Re: parting out a case 310 in reply to Hilario Fernandez, 05-09-2006 08:31:56
Where are you located? I'm interested in the crank and pulley, e-mail me at the above address. Thanks, Steve
Hilario Fernandez
05-12-2006 07:11:00
 Re: parting out a case 310 in reply to Steve Rhoads, 05-12-2006 06:25:39
LIKE I MENTIONED BEFORE...SOMEONE TACK WELDED THE NUT THAT HOLDS THE PULLEY TO THE CRANK. I CAN REMOVE THE PULLEY FROM THE CRANK BY DRILLING OUT THE TACK WELD. THE CRANK IS GOOD BUT YOU WOULD HAVE TO PROBABLY TACK WELD THE PULLEY BACK ON TO IT IN ORDER TO USE IT.I DO NOT THINK THAT I CAN REMOVE THE CRANK FROM BELOW THE ENGINE WITHOUT REMOVING THE PULLEY. I WOULD TAKE $70.00 PLUS SHIPPING FOR BOTH THE PULLEY AND THE CRANK. LET ME KNOW AND I CAN SEND SOME MORE PHOTOS. TO SEE SOME PHOTOS OF THE TRACTOR GO TO
WWW.GEOCITIES.COM/[email protected]/FRONTPAGE
hilario Fernandez
05-15-2006 09:53:23
 Re: parting out a case 310 in reply to Hilario Fernandez, 05-12-2006 07:11:00
go to to see photos of the tractor. I can remove any part you need. www.geocities.com/[email protected]/
frontpage
flynno
05-22-2006 14:22:31
 Re: parting out a case 310 in reply to hilario Fernandez, 05-15-2006 09:53:23
Where are you located? Might be interested in rims and/or front axle.
hilario
05-23-2006 18:33:36
 Re: parting out a case 310 in reply to flynno, 05-22-2006 14:22:31
I am located in houston texas 77021.
