Case SC hydraulic cylinder
Gobind Khalsa
05-08-2006 05:41:50
My '55 SC's hydraulic cylinder (that lifts the Eagle hitch) just started leaking fluid out the top - probably blew a seal. What's involved in fixing this? Is it something a amateur mechanic can do? Parts? Special tools? Any help appreciated. Thanks.
Paul f
05-08-2006 05:55:30
 Re: Case SC hydraulic cylinder in reply to Gobind Khalsa, 05-08-2006 05:41:50
I did my DC cylinder...no special tools. You will need O rings and seals. (You will have to check your parts manual as I believe the SC cylinder is different than my DC. Only tip is make sure you drain the reservoir and lift teh arms up and down by hand to get most of teh the fluid out of teh cylinder before you start. I am sure you will still get some on the floor (AT least I did so be ready). Also you must remove the pipe elbow at teh top of the cylinder to get the end cap out....
Gobind Khalsa
05-09-2006 05:41:32
 Re: Case SC hydraulic cylinder in reply to Paul f, 05-08-2006 05:55:30
I looked thru my owner's manual and service manual - no mention of hydraulic cylinder service. Ordered the "SC Hydraulic Attchments Service Manual" and Parts List. Hopefully I'll get the info I need. Do Case IH dealers have the parts, other recommended sources? Thanks.
Paul f
05-09-2006 05:53:12
 Re: Case SC hydraulic cylinder in reply to Gobind Khalsa, 05-09-2006 05:41:32
Email me and I will send you scans of the 3 pages that describe teh cylinder overhaul. Can't help with part #s...Case dealer had all I needed for DC....O-rings can be had at any tractor/hydraulic place
