LA pistons wanted
mole
05-06-2006 21:42:59
I am looking for a set of pistons and sleeves for an LA. prefer 4 7/8 bore but am not too picky at this point. As long as they are in very good condition as I plan on playing with this one quite a bit on the plow. New old stock would be great but I figure probably not likely these days. I have a set of 4 5/8 high compression pistons and sleeves for the L that are almost new condition. Possible trade?
mole
05-08-2006 22:08:06
 Re: LA pistons wanted in reply to mole, 05-06-2006 21:42:59
Thanks for the info. Checking with Don did cross my mind after I posted my message.
elroysdad
05-08-2006 15:59:15
From your post I am assuming that pistons and sleeves will not interchange between L and LA models? I need a set for my L and always figured they were the same. Could one of you guys let me know if they will work in either tractor or not. Thanks, John.
mole
05-08-2006 22:04:50
 Re: LA pistons wanted in reply to elroysdad, 05-08-2006 15:59:15
I am not sure about all of the piston combinations I think they will but the set I have will not. My set is a high compression set for the L. They are flat top not domed. The top extends about another 3/16 - 1/4 inch higher than standard. The piston will hit the head on an LA because of the chamber only being just enough for the valves. The L head has a full opening about the bore size. The pistons go up into this opening at the top of the stroke thus being higher compression.
Richard G.
05-08-2006 05:29:39
I have a set of very good 4 7/8 aluminum M@W high compression pistons I will sell. I had some one interested about a month ago but lost their Email.
Let me know if you are interested.
Richard
Walt Davies
05-07-2006 22:09:44
I have set of 4 5/8 pistons and rods the rods have good bearing and the piston are used but not much. get in touch off list for the price. They caost quite a bit to ship. Walt
Monmouth, Oregon
Les
05-07-2006 18:32:44
Have you tried Don Livingston?
