CASE 870 hydraulic remotes
shane louderbac
05-05-2006 11:30:21
Has anyone ever had issues with the remotes hydraulics not working? When I hook up a cylinder to the tractor and try to raise it might raise it only a couple of inches and stop. And then when I want it to go back down it comes back down but very slowly. I am pretty sure my hydraulic pump is ok, since i have good pressure and my power steering, brakes and transmission seems to be working ok. I also have enough fluid and my filters are ok. I think the problem is somewhere in the remote valves but i am not sure. Would anyone have any ideas?
oldrusty
05-05-2006 11:51:24
 Re: CASE 870 hydraulic remotes in reply to shane louderback, 05-05-2006 11:30:21
Hook one hose on top left hand side and the other on the top right hand side. if this does not work the check the couplers and make sure that they are opening when hooked up.
John Saeli
05-05-2006 11:42:02
Hey Shane: Do both remote circuits bother? Does more than 1 remote cylinder bother? We had a problem with our haybine, & it turned out to be the male ends. Changed them & the problem went away.
