Case 530CK Foot Petal
Phil (NJ,AZ, Sa
05-04-2006 08:52:49
Sometimes the obvious is missed!
I had a gradually deteriorating problem that I thought was my COM Clutch (almost tore it apart). The unit would hardly pull itself around when using the front loader (Manual lever @ Idle for shuttle operation) using the foot feed to control RPM .. but the problem was slop & wear in the Foot Petal resulting in reduced RPM.
The petal had been repaired (welded for wear) some time in the past but wore the pivot bolt & holes in the mounting bracket. Welding Steel washers to the inside holes of mounting bracket & a new Pivot bolt along with adjusting the assembly to obtain Max RPM solved all my problems. Tractor is now restored to full power.
Hope this helps,
