Identify Case wide frontend
Jerry W
05-02-2006 17:27:04
Just posted a picture in 'Help Identify' section of a Case wide frontend that came off of a local guys' iron pile. He thought it was VAC but we knew when we saw it that it was not. It has a split tie rod setup in front of the axle and had a wishbone type control arm that someone cutup.
Thanks Jerry
Hank (MO)
05-04-2006 04:10:17
 Re: Identify Case wide frontend in reply to Jerry W, 05-02-2006 17:27:04
It does NOT match the adjustable WFE that was available for the VAC. I can't speak for a VA though.
Jerry W
05-04-2006 05:12:41
 Re: Identify Case wide frontend in reply to Hank (MO), 05-04-2006 04:10:17
Hank
We know it is not a VA front end. We were told that it was but noticed right away that it was different. I was just curious as to what it was. It is real similiar to a late VAC adjustable wide front except for the bolster.
Jerry
Bernsy MN
05-03-2006 18:43:20
It looks identical to the front end on my 311 case. Bernsy
Jerry W
05-03-2006 21:30:16
 Re: Identify Case wide frontend in reply to Bernsy MN, 05-03-2006 18:43:20
I have been fairly well convinced that it is off of a 300 round nose Case.
Thanks
Keith-OR
05-03-2006 07:47:49
Here is the front end you saved. It is off a VAC 14...
Keith & Shawn
third party image
third party image
Joe (Wa)
05-02-2006 23:37:23
Looks like 300, 300b, 400b GP tractors, measure spindle height overall 18.5". Longer spindle may be 500b or 600b.
Joe
BarryfromIA
05-02-2006 18:50:28
Is that a ball type pivot on rear of the wishbone? My guess is a case o matic tractor. A 400b.
this
05-02-2006 17:59:46
third party image
AL BOY
05-02-2006 17:32:18
Looks like it,s from a 300 Case.
