scania motor
4 R's
05-02-2006 11:52:54
can't seem to catch a break w/ the 4890. had the heads surfaced put them on and water is still leaking from the headgasket in the front and on the side. I need help on figuring out what i need to do to get it going. I can't seem to find a dealer that knows alot about the motor.
Triplerange
05-04-2006 05:07:15
 Re: scania motor in reply to 4 R's, 05-02-2006 11:52:54
My advice: drop in a Cummins 855 cu in.
Mathias NY
05-02-2006 12:34:27
A could of idea:
When you had the heads planed, did they check the head for cracks?
Are the cylinder sleeves installed correctly? Perhaps the front sleeve is sitting slightly higher than it should.
There is also a chance that there could be a problem with the block itself that would cause the head to not sit correctly.
c hess
05-02-2006 12:33:10
Binkley an Hurst @ Lititz Pa had 1 of those brutes at there place 1 time. They might be of help. 1-800414-4705 Long time Case folks
