What a weekend!?!
PhilcaseinWPa
05-01-2006 09:39:08
This is going to be long so bear with me.
All I wanted to do Saturday was get a little sweet corn in. First I had to plow, my schedule and weather finally agreed. I got the 885 out and drove to the plow. Well the plow had upset during the winter so I had to use a chain on the 3ph to set it up. No problem except the 3ph decided it didn't want to raise. So drove back to the shop and called the dealer who had done $3000 work (including new pump) on the hydralics in January. Well after trying several things and several phone calls finally decided the system was sucking air somewhere. Checked the O ring on the hydralic filter housing and it seemed ok. Replaced the filter housing and tightened it down good. Then cycled the 3ph a few times and everything seemed ok. Went and hooked up the plow and everything seemed fine. Plowed for 3 hours with no problems ..... except the TA would not stay in high. It was constantly shifting down and up when the switch was in high, in low it would stay in low so I plowed with the TA in low all morning. I had this problem last spring .. that is one of the reasons it was in the shop. After lunch went back out to use the tractor and the 3ph is acting up again but after a few jerky lifts and cycling through a few time it worked ok. Remote cylinder on the disk worked fine, power steering worked fine, pto engages ok. All these operate off the same pump. is anyone still reading? So today I finally got my corn planted. When I first started the 3ph was jerky and would hardly lift the planter. After reving the engine and cycling the 3ph it worked fine. Worked fine the entire time I planted. When i got back to the shed and took off the planter the 3ph acted up again. It seems to require high engine rpms to work right even without a load or it has to cycle through several cycles before it works smooth even without any load. one other stange thing... when you first start it the first lift is fine then it acts up. Maybe it's time for one of them green or blue tractors. Any thoughts?
DKase
05-01-2006 19:48:31
 Re: What a weekend!?! in reply to PhilcaseinWPa, 05-01-2006 09:39:08
It sounds like you have a leak in the suction line to the hydraulic pump. DK
Walt Davies
05-01-2006 19:33:24
I don't know about you but if I paid good money to get it fixed I have it right back down to the shop where it worked on and I wouldn't bring it home till it fixed correctly and I sure wouldn't pay them for the extra work either. I'm kind of funny like that after being a Mechanic for 40 years I expect others to do the job correctly or do it over for free. Walt
PS its not your fault there Mechanic doesn't know his job.
Walt Davies
05-01-2006 19:33:21
Walt Davies
05-01-2006 19:40:36
 Re: What a weekend!?! in reply to Walt Davies, 05-01-2006 19:33:21
That's funny it posted twice. I wonder how it did that.
Walt
GeoMo
05-01-2006 12:35:15
Wash your mouth with soap
