Case David Brown 995 rear lift not working
Fulgham
05-01-2006 09:13:27
Hi, I just purchased a David Brown 995 with a front end loader. The front end loader works great, but the rear lift does not work at all. The guy that I purchased it from said that the rear lift was working and then it became sluggish, and one day recently, it just stopped working completely. Does anyone have any idea what my be the problem? Thanks.
cj3b_jeep
05-01-2006 12:59:12
 Re: Case David Brown 995 rear lift not working in reply to Fulgham, 05-01-2006 09:13:27
My guess is that something in the three point valve on your remotes is jammed/clogged up. Try turning off the remote for the loader, and opening/closing the three point valve. Could have a clogged orifice somewhere in the system
Fulgham
05-01-2006 12:32:15
The 3 pt is in the down position.
cj3b_jeep
05-01-2006 11:25:57
Does it have a set of remote valves? Some of the older machines you had to turn off the three point to work the loader. Most likely a valve problem if your loader works well
fulgham
05-01-2006 12:30:54
 Re: Case David Brown 995 rear lift not working in reply to cj3b_jeep, 05-01-2006 11:25:57
Yes, the tractor does have remote valves.
jimtex
05-01-2006 11:16:57
is the 3 point in the up position?
tja toolbx
05-02-2006 07:33:37
 Re: Case David Brown 995 rear lift not working in reply to jimtex, 05-01-2006 11:16:57
If you search the old post you find a couple of question and replies. Look for the replies posted by Elmer, he really knows David Brown.
