Hydraulic fluid level
Sans
05-01-2006 03:40:01
Reservior tank for my hydraulic fluid is empty. I could not find in the manual how much I should have in the tank. I was afraid to put too much in. There was no dip stick. Also, are there different fluid grades?
Any suggestion?
Walt Davies
05-01-2006 09:07:39
 Re: Hydraulic fluid level in reply to Sans, 05-01-2006 03:40:01
We need a few more facts what kind of tractor what type of equipment do you any one way rams on it. that is a ram like the one a forklift where it pumps up but runs back into the tank under its own pressure. these type rams must in the fully closed position to check fluid levels. Two way rams use the same amount in or out. Some older tractors use one way rams on the loader. With information this we may be able to help you better. Walt
