L Case puller
gold-leaf-deere
04-30-2006 19:57:41
check out e bay 4635262590. The L has 1300 cubes , 4100 pounds and over 300 horsepower, could DC Tom compete with this beast?
dctom
05-01-2006 12:26:03
 Re: L Case puller in reply to gold-leaf-deere, 04-30-2006 19:57:41
never know till you try, would be fun lol tom
gold-leaf-deere
05-01-2006 10:19:18
I have pulled a tractor with 1384 cubic inch four cylinder engine,it will turn 300 R P M. The name tag says AULTMAN TAYLOR 30-60, just wanted to compare the cubes.
Chances R
05-01-2006 11:58:24
 Re: L Case puller in reply to gold-leaf-deere, 05-01-2006 10:19:18
third party image
You forgot to add a picture Pop.
Walt Davies
05-01-2006 09:00:40
I'm still curiuos how he took a tractor that weighed 5700 lbs dry weight and added all that engine and got it down to 4100 lbs what did he remove. And why would he put so little on the add for a $10,000 tractor I would think that he would get more action if he disclosed a few things about the tractor other than it used to a 1929 Case L.
Walt
Thad
05-01-2006 09:54:58
 Re: L Case puller in reply to Walt Davies, 05-01-2006 09:00:40
I looked it over well at our first pull. It has tons of aluminum on it. They can pull under 5000 easy. I have a freind who pulls one stock fenders and all under 5000 barely. He only weighs 120 lbs wet though.
Thad
05-01-2006 07:21:20
It weighed 4170 or so with a man on it at our first pull this year. It should be 1018 cubes its a Shipman built tractor. Really neat machine makes my 522 cube L look like a baby. Thad
Brian in Ohio
05-01-2006 05:15:48
DCTom... probably not...
Don Livingston with his LAI... now THAT would be a good challenge...
930
05-01-2006 05:15:41
The L is not for the slow minded puller. I know of the builder and he does not build tractors for the weak at the wheel.
DBoll
05-01-2006 05:04:05
I pulled with a guy that had an 850inch L, he then built a 1000incher,the 850 really pulled better, couldn't make the head flow to utilize the displacement. Kinda like the big inch deeres. biggest isn't always best.
gold-leaf-deere
04-30-2006 20:11:41
I got the info from the one who has it on E Bay,I E mailed him and he replyed back
Walt Davies
04-30-2006 20:08:09
Where did you get the CID and weight from its not in the add. From what is there its a lot like buying a Pig in a POKE. Walt
