LA Brake Drum Removeable
jas harrison
04-30-2006 11:37:46
I"m trying to get to the wheel cylinders to rebuild them. However the brake drum will not move, so far I have removed the 2 3/4 inch nut that holds the drum on, made a bottle jack puller, and the drum will not move. any suggestion"s?
Walt Davies
04-30-2006 19:52:05
 Re: LA Brake Drum Removeable in reply to jas harrison, 04-30-2006 11:37:46
I have a 48 LA for parts with Hydraulic brakes the brake shoes were frozen to the drums and no way to collapse the cylinder so I made a puller from a heavy piece of metal and used two big bolts to screw into the holes near the center of the drum I think they are 3/4 NC. also a 1 in. NC bolt in the middle to put pressure on the shaft. Graind a point on this one and use a nut under the metal plate. clean the bolt holes in the drum with a bottom tap before proceeding.
I drilled two holes in the inner side of the drum facing where its not so thick and used an air hammer and punch to loosen the shoes. Then with lots of heat from a rosebud and a large wrench to turn the bolts in I had it off in about two hrs. It ain't easy and its also ver heavy so have a good winch or use the bucket on your loader like i did to hold it up whe it comes off. You don't want drop it on a toe, believe me. Also remove all nuts that hold the shoes in as they will most likely come off with the brake drum. You will peobably need new parts as this is not an easy task. Walt
Richard G.
04-30-2006 17:40:45
I have a LA with hydraulic brakes and removed the drum with a puller made with 3/4 plate and a 20 ton jack. My 8 ton jack would not even budge it.
Richard
wilson
04-30-2006 16:16:30
Probably its a L I at least i havent seen an L A with hyd brakes Try putting nut on with about one eigth to three sixteenths slack to the hub and driving SLOW. Be sure to put cotter key back in.
