580C
rwtaylor
04-30-2006 04:40:40
During start up and running. I have a steady flow of oil coming out of the blowby hose. I was told I might have a return line plugged.
Any help would be appreciated.
Roger (Mi)
05-02-2006 05:31:57
 Re: 580C blow-by in reply to rwtaylor, 04-30-2006 04:40:40
If the blow-by coming out of the blow-by tube is nearly as great as the exhaust coming out of the exhaust pipe, it's time for an overhaul. Believe me, I've seen some nearly that bad. Don't be surprised if it has some broken ring landings on the pistons. A piston/sleeve set can be installed in-frame. A compression check will confirm the status of the engine. It should have 400 PSI at a 200 RPM cranking speed.
