case 1030
WELDON
04-29-2006 21:20:26
Ihave a case 1030 that is leaking fuel out of one head.It also misses.While it is running it blows white smoke.Changed one injector in that head Old one had carbon made no differanc.Any ideas?
c hess
04-30-2006 17:12:24
 Re: case 1030 in reply to WELDON, 04-29-2006 21:20:26
Not sure where it is leaking fuel but if at ext manifold an since you already put in new injector my guess is has no compression in that cylinder an is not burning fuel or powercell may be plugged with carbon .Both will cause miss.
CNESLER
04-30-2006 13:43:52
White Smoke is most likly water
I have had pin holes in the injector lines
spray on the head and cause a miss.
Good Luck
CNESLER
jim handke
04-30-2006 08:41:55
Are you losing water? Cracked head, maybe.
