Case Vac help
Dale Cottingham
11-08-1999 16:22:09
I have a Case Vac 1951 year the powerlift works good but doesn't let a plow down like it is suppose to. It lets down real slow. It has a Eagle Hitch lift, any information would be appreciated. Thank you for your time
Wolf
11-10-1999 06:32:15
 Re: Case Vac help in reply to Dale Cottingham, 11-08-1999 16:22:09
Dale, I agree with Larry. If you don't have a manual, and you have access to a fax machine, let me know and I can fax you copies out of the manual for making these adjustments. It should be lowering just fine with an implement attached in no time at all. Which reminds me, I need to adjust mine just slightly as well.
Larry
11-09-1999 21:14:07
First thing is don't listen to any red tractor jerks.Those red pigs didn't know what a lift system was until everyone else had one.Now to your problem.Check to see if the hydraulics have an adjustable valve that you can adjust for lowering speed.A owners manual should show you how to adjust this.
Red Blooded
11-09-1999 17:15:16
Mr Dale, you don't have any problems that a little time & money won't fix, first of all you need three jacks, and some blocks, put a jack inside each rear wheel and one jack just behind the front wheel, now at this point, you start jacking and blocking,jacking and blocking,being real careful { always practice safety } jack your case up about 10 foot high, now that you've got it blocked up real good ,come on out here where i'm at,and buy you a good red farmall and drive right up under that case and all your problems will be solved Thank You Red Blooded @ Midway
Jerrie Lott
11-10-1999 16:21:12
 Re: Re: Case Vac help in reply to Red ed, 11-09-1999 17:15:16
Mr Red ed should stay on the Farmall site if he can't be courteous. Farmall didn't even have any kind of an implment lift till about 1955 and then you could only use special implements made especially for their lift so he shouldn't bad mouth someone elses equipment when it don't work.
Larry
11-10-1999 17:25:56
 Re: Re: Re: Case Vac help in reply to Jerrie Lott, 11-10-1999 16:21:12
I wouldn't have a Farmall stuck in my butt if I had room for a truck load!
