Case 1030 Hydraulics
Dellbertt
04-29-2006 10:24:31
Anyone know why my Case 1030D has no lifting power to the plow cylinder.
It will move in the freeplay to the stops but will not lift the plow.
The lever will not stick in up or down, I have to hold the lever for and aft.
Fluid is ok.
Something stuck open or closed?
Grumpy
04-29-2006 17:14:28
 Re: Case 1030 Hydraulics in reply to Dellbertt, 04-29-2006 10:24:31
There are two places that could be the problem. Your pump could be wore out or you could have a problem with the relief valve. You need a flowmeter to check the pump flow under pressure to decide which is bad. If it works a little better cold than warm then I would lean toward the pump being the problem. The relief valve is under a large cap on the bottom of the remote valve body. It takes a 1 1/4 wrench. The valve body has to be removed from the tractor. The fuel take has to raised up or removed to get the valve off. You might find a blown o'ring or you might have to replace the whole relief valve. Stan
Dellbertt
04-30-2006 08:29:35
 Re: Case 1030 Hydraulics in reply to Grumpy, 04-29-2006 17:14:28
Stan,
I have a parts catalog but it doesnt show where the pump is located. Is the pump located up in the same housing near the relief valve and control valves.
Dell
Grumpy
04-30-2006 14:44:26
 Re: Case 1030 Hydraulics in reply to Dellbertt, 04-30-2006 08:29:35
There is a big steel hyd. line coming out of the pump right above your third link. That is your pump. it is easy to change but is pricey. Stan
Dellbertt
04-30-2006 18:02:12
 Re: Case 1030 Hydraulics in reply to Grumpy, 04-30-2006 14:44:26
Stan,
Thanks for the help.
I tried to half an aluminum pump for my 300U ground and oversize gears installed but it was wore to much. Cost 700 for a new one.
Thanks again, Dell
c hess
04-29-2006 13:05:39
Remotes or 3point not working.?This would help those who know how to help
Dellbertt
04-29-2006 15:05:43
 Re: Case 1030 Hydraulics in reply to c hess, 04-29-2006 13:05:39
rockshaft(3.)works fine.
The remote shaft works only with no load.
It will not raise the plow.
