a little sputter
Rob Garrick
04-28-2006 11:53:56
I recently tunned up my 53 VAC, set the timing and rebuilt the carb. When idling she still lets out a little sputter now and then. I asked my local dealer about it and they said those old 4 cylinder strokers do that a little. "Take your rain gaurd off" I thought I may of had a sticky valve. Has anyone come across this?
Glenn F.
04-28-2006 17:43:56
 Re: a little sputter in reply to Rob Garrick, 04-28-2006 11:53:56
My SC CASE does that as well. My neighbor(retired GM mechanic) was over. He heard it running and said it was most likely in the carb/carb adjustment. I do know we hobby guys are worried over things the real farmers never noticed. My SC pulls just fine, so I guess I'm not too worried either. Glenn F.
Rob Garrick
05-01-2006 04:42:57
 Re: a little sputter in reply to Glenn F., 04-28-2006 17:43:56
Yeah, I used my tractor all weekend and she performed beautiful. It doesn't do it when under load. I tried playing with the carb a bit, the rich/lean adj. screw seams to effect it a little. What I found was I could reduce it by tighten up the screw but when working the tractor at higher rpm she staved for fuel. I am just going to ignore it.
