need case model identified
mike wegley
04-28-2006 11:25:38
just purchased a older case farm type tractor, 4cyl gas model G159B, transmission # 2271698 the tag for the tractor model number was removed. I'm trying to find out what model the tractor is so I can get parts, info. etc. etc. can anyone assist???? greatley appreciated!!!!! !!!!
Mike
Tom (Ks)
04-28-2006 17:48:11
 Re: need case model identified in reply to mike wegley, 04-28-2006 11:25:38
Your transmission SN is larger than my tractor, and the 159 engine would be used in 530's and 570's. I would guess you have a very late 530 or a 570. The 570 will not have the eagle between the two headlights.
james363
04-28-2006 16:33:22
if you can find the serial number you can try case archives 262-636-7274 or look in tractor registry
mhwsaw123
05-07-2006 18:00:53
 Re: need case model identified in reply to james363, 04-28-2006 16:33:22
Thank you for the help. I forgot to add that my transmission is only 3-forward and 1-reverse. I'm begining to think it might be a CK, either 530 or a 570, does anyone know what type of transmission fluid it uses and it appears to have a different fluid for the hydraulic clutch compartment.
mike
