Case 930 sterring column
Seth Davis
04-27-2006 19:54:21
Will a 67-68 Case 930 steering column fit on a 66 Case 930? Thanks, Seth
Seth Davis
04-27-2006 20:14:47
 Re: Case 930 sterring column in reply to Seth Davis, 04-27-2006 19:54:21
Disregard the first question. Does the 68 Case 930 have the same steering system as the 66 930 Case? Will a 970 steering system fit on a 66 Case 930
Roger H
04-28-2006 07:19:02
 Re: Case 930 sterring column in reply to Seth Davis, 04-27-2006 20:14:47
the 30 series systems should be the same from year to year unless you try to use a row crop system on a western special or vice versa. the western's gear box works opposite of the row crop, in other words if you put a western gearbox on a row crop when you turn left, you will go to the right
