Water in oil 1950 VAC
WK-WA
04-27-2006 19:40:15
Problem: Water in oil. This is gravity flo, will aquire about 1/4 cup in 24 hrs. Compression is 55-65 all cyl's. Spark plugs are black (carboned). No oil in radiator. Runs great, not missing, etc. Decided to run this by the board before tearing apart. Where to look? Gasket between the block and timing gear cover, Head gasket, Cyl o-rings, Cracked head?? I checked the past discussions and one response was to get a can (bottle) of block sealer, fill with clear water, bring engine temp. to 180, drain, and fill with proper coolant. (That is if it stopped the leak)
Thoughts? Advice??
Eric Foster
05-01-2006 16:20:06
 Re: Water in oil 1950 VAC in reply to WK-WA, 04-27-2006 19:40:15
I had the same problem. I pulled the head and had cracks between 1 & 2, 2 & 3 and 3 & 4. I had a neighbor that recommended grinding out and using JB Weld. I decided to try the block seal (someone on this site recommended it).
It Worked. I worked the snot out of it last year and some this year. Everything is still holding. I would try it before you bother tearing everything down. What do you have to lose?
Good Luck,
Eric
Jerry W
04-27-2006 20:06:32
I'd pull the pan and then put some air pressure to the radiator - shouldn't take more than 5 to 10 psi. If you are leaking with a non pressurized system it should leak right away with a little air. You might be able to see where the leak is by staining. Also look for cracking in the webs which is common a block that has froze.
Jerry
Jerry W
04-27-2006 20:01:53
My bet is on a sleeve oring leaking.
Jerry
c hess
04-28-2006 10:10:55
 Re: Water in oil 1950 VAC in reply to Jerry W, 04-27-2006 20:01:53
I would bet on cyl o ring leaking also. Would also try radiater sealer first. We used to put Bars leak in all engines leak or no leak. Cant use with new ones with filters though.
