case 700 american bosch
huey
04-27-2006 19:04:15
Can this pump be adjusted for altitude to reduce smoke? How?
57 Case
04-29-2006 20:24:16
 Re: case 700 american bosch in reply to huey, 04-27-2006 19:04:15
On the Bosch PSB pump The fuel is sdjusted with a sliding stop under the Rectangular cover (4 bolts) at the Back top, behind the Pump Head. The stop is held by two bolts move it back for less fuel. You can also adjust the tip on the end of the arm that contacts the stop.
D boll
04-29-2006 13:34:24
make a tool out of a fence staple, smoke screw is under a plug if I remember correctly
