Case 611B
Mike Morin
04-25-2006 21:20:37
I have a 611B case o matic. The transmission works fine. The eagle hitch will only lift twice when motor is first started but will not lift after that. Second lowering is choppy. I was able to use the back blade for one day but found the hitch would only lift if engine was at idle. Since then it won't lift accept twice when cold. Checked filter and it was clean. Oil level is correct. Any ideas?
Roger (Mi)
04-27-2006 04:35:01
 Re: Case 611B hydraulics in reply to Mike Morin, 04-25-2006 21:20:37
The Case-0-Matic and the hydraulic system both draw oil from the torque tube. Each has its own oil pump and filter. The hydraulic filter is near the hydraulic control valves. The hydraulic remote valve lever (if moved) should cause the engine to slow down slightly as the relief opens. If it doesn't, there is a problem with the hydraulic pump, relief (located on the hydraulic pump), or the hydraulic pump intake tube.
