Case 430 Air filter on front
Paul in On
04-25-2006 19:35:29
Got a Case 430 and was wondering if there should be oil in the front plastic piece. At least I think it's the air filter. Maybe I',m wrong - quite possible.
Joe Young
04-26-2006 05:17:08
 Re: Case 430 Air filter on front in reply to Paul in On, 04-25-2006 19:35:29
Paul
If you are refering to the clear plastic "bowl", with aluminum lid on top of the hood, the answer is no. That is a pre-cleaner. The oil should be in the bottom of the assembly behind the front screens and below the hood. Loosen the band by turning the "thumb-screw" while holding the cup on the bottom of the assembly. The cup will drop down (or fall down if you are not careful) for servicing - Joe
