case vac14
vic vansickle
04-25-2006 06:50:07
I have inherited my grandfathers case vac 14 serial 6013942 . I have had the starter rebuilt, new coil, and new 6volt battery but it still turns over very slow. It is pos ground and when i jump start it it cranks over fast and starts right up. should i switch to 12 volt system and if so what do i need. Also i wondered if someone could tell me the year of the tractor by the serial number.
F-I-T
04-26-2006 08:45:57
 Re: case vac14 in reply to vic vansickle, 04-25-2006 06:50:07
third party image
Vic:
In addition to the good advice you received on clean cables and large diameter connectors, I have found that moving the ground line to a point close to the starter shartens the ground return path and seems to let the starter run cooler and spin with more attitude! On my VAC I routed mine to bolt onto one of the starter flange bolts. Not exactly collector correct, but it sure works for me.
I also endorse using Optima Batteries. 1,000 Cold Cranking Amps.
Mine will start with a plow in the ground in 2nd gear..... .not that I've done that..... .
Frank
JustIn Case
04-25-2006 13:34:36
I have 1946 vac that cranked slow even after the starter had previously been worked on. The uncle I bought the tractor from thought maybe the starter was dragging. What I found was where the ground cable connected to the tractor was rusty, dirty etc.. In this case the groundcable connected through one of the bolts that held the dash to the steering column. I cleaned all of the mating surfaces as best I could using a wire brush,file & emery cloth. Used a new shiny bolt for re-assembly and it really seemed to help it. P.S. This tractor is still 6 Volt and still starts pretty good even down to say 20 degrees. Jim
jal-SD
04-25-2006 11:31:30
Make sure the cables are "CLEAN, BRIGHT & TIGHT". If they have been replaced, they are probably cables designed for 12V systems. 6V cables need to be much heaver than those commonly sold at parts houses that are used on 12V systems. You should use "0" or "00" cables. If you can't find them at a parts house, a good one or an implement dealer can make some for you. (My $0.02 worth. jal-SD)
Paul f
04-25-2006 13:11:56
 Re: case vac14 in reply to jal-SD, 04-25-2006 11:31:30
Second JAL comments. With the heavier wires my VAC cranks like a 12 volt system...much faster than my DC
MikefromIowa
04-25-2006 10:13:37
Personally, I wouldn"t change it over to 12V unless you use it in the winter where its cold. I mow 3 acres of grass per week with my "48 VAC. It is 6 volt and doesn"t turn over more than once and its running. They are not hard starting(or at least any I"ve seen). the "14" is has a lowered passenger area. the foot rests are beside the torque tube, the older ones everything is on top. they also changed the steering setup. and probabily other things, I"m not thinking of.
Graham from NZ
04-25-2006 08:17:10
According to the "serial numbers" in the research info on this site your VAC would be 1956, but the VA is listed as 1954. I don't know what the '14' means. It is not listed separately.
'53 VAI Guy
04-27-2006 20:28:18
 Re: case vac14 in reply to Graham from NZ, 04-25-2006 08:17:10
I agree. I have a VAI with SN beginning with 600. I thought it was a '56, but from what others have told me, you can not use the "Case Numbering System" (first two digits, minus 4) on the early/mid 1950s VA Series Tractors. In this instance, I believe mine to be a '53. It is a 12 volt system (I bought it that way). After wiring lights on it, I'm kind of glad it was 12 volt. I wired it just like any other vehicle in my driveway. Good luck.
