I give up.....timing a D
P Backus
04-24-2006 11:03:51
I posted here a couple of weeks ago (I"m from the IH forum mostly) about a friend"s D that we were trying to get timed. Well, I went over there yesterday and got it working for him (he had the mag timing 180 degrees off), but i still can"t find where the TDC mark would be. I just timed it by sound once we got it running. Is the mark on the flywheel? I couldn"t find an inspection hole, save for the clutch adj covers on each side. The thing is, they are behind the flywheel and all you see is the clutch. Is the mark on the front pulley? I couldn"t see anything in there, at least partly because of the huge, industrial loader on it (which is rated at 4000 lbs- that ought to be good for the front axle, eh?). I was surprised to see that battery polarity is 6v negative ground.
Someday we"ll probably have to adjust that clutch since it just barely seems to lock in. I"m hoping that"s not too tough..... is it?
One of my IH tractors actually has a hand clutch, so I am familiar with that system. I think he needs to get a manual for it!
Paul
Walt Davies
04-25-2006 11:37:32
 Re: I give up.....timing a D in reply to P Backus, 04-24-2006 11:03:51
My LA has a bosche magento instead of the Case and I could not get it running right for the life of me so i took a cover plate off the side of the engine put number on right on top dead center and maked the from pulley.
I then used some simple math measured the distance around the front pulley and devided it up to get 30 degrees. I then marked that and used a timing light on number 1 to set the engine at 30 degrees at full throttle. it runs great now.
Walt
P Backus
04-25-2006 13:07:51
 Re: I give up.....timing a D in reply to Walt Davies, 04-25-2006 11:37:32
What a neat solution! I"ll bet that works pretty well. How did you know exactly where TDC is, or did you use the flywheel mark?
Paul
Walt Davies
04-28-2006 16:15:51
 Re: I give up.....timing a D in reply to P Backus, 04-25-2006 13:07:51
I opened up the engine side covers and whatched the front rod until it was top dead center. I didn't know if the mark on the flywheel was TDC or not.
Walt PS it runs great now lots of power at both ends top and idle. You have to be sure to set the advance back when starting though. The LA has a manual advance like a model T.
Dale L
04-24-2006 11:44:15
Paul there is a pipe plug on the right side of the tractor[right side if you are sitting on the tractor] just bellow the housing for the starter on the transmision case. Pull the plug on the number one cylinder [frount cylinder] turn the engine over until you fell compression. When the number one cylinder is top dead center a D will be lined up in the hole. The mark is on the side of the fly wheel. To be sure the timing is TDC turn the engine over slowly when the impulse coupling trips[ making a clicking sound] the d sould be centered on the hole. There that should totally confuse you! AS for the clutch you have to adjust it from the left side of the tractor. Remove the hand hole on left side of the tractor. There is a spring loaded pin that you have to depress and then spin adjusting ring counter clockwise to tighten the clutch. You should only have to spin it one or two notches. I just adjusted the clutch on my DC, I had a hard time getting the locking pin back out again. I hope that help Good luck Dale P.S. That pin is in there it's just hard to find.
P Backus
04-25-2006 06:18:03
 Re: I give up.....timing a D in reply to Dale L , 04-24-2006 11:44:15
Thanks Dale! No confusion, that"s the info that I needed. I didn"t see that pipe plug, and I was looking for it. I"m thinking that the loader bracketry probably was covering it up. We"ll get at the clutch too eventually.
Paul
