442 Lawn Tractor
Jerky
04-23-2006 19:38:33
Runs good for five minutes.
After oil warms up, it slows down and gets jerky.
Won't pull itself up a road ditch when mowing.
Looks like thicker oil than Hy-tran.
Someone on here once said to use 30 wt motor oil.
I'd like to know from someone with authority what
Case says to use for oil 35 years ago and what
oil would be the same thing today as most oils
have changed brands/names by now.
I have access to CaseIH or Cenex oils mostly.
If my oil is correct, do I need to rebuild or replace the hydraulic pump and which one?
The one on the motor, or the one on the transmission? Any solid info would be greatly
appreciated. Thanks!
Engineer20
04-24-2006 07:38:55
 Re: 442 Lawn Tractor in reply to Jerky, 04-23-2006 19:38:33
Most are using 15-40 for the tranny.
John Noname
04-24-2006 15:57:45
 Re: 442 Lawn Tractor in reply to Engineer20, 04-24-2006 07:38:55
All the ones I had in the past, 83, 85, and 88 all called for 10-40 in the manual. I'd drain it and get good clean oil in there the first thing.
