case 770
Josh Dubie
04-22-2006 18:53:37
Does the sheet metal for a case 770 interchange with say a 970 or 1070? Also are there any major problems with 770s?
thanks in advance
dwag
04-23-2006 17:45:37
 Re: case 770 in reply to Josh Dubie, 04-22-2006 18:53:37
Do you have one spotted? A friend of mine is looking for a 770 diesel.
Thad
04-23-2006 16:49:55
All the front sheet metal is diffrent. A 770 and 870 are the same. A 770 is a good big small tractor. What i mean is they are a big sized tractor for their HP. Hope this helps. Thad
Mikey
04-23-2006 18:09:54
 Re: case 770 in reply to Thad, 04-23-2006 16:49:55
The way I understand it is that except fot the engine:
The 470 & 570 are the same.
The 770 & 870 are the same.
The 970, 1070, 1170 & 1175 are all the same except for the cast-iron nose piece on the 1170.
The 1270, 1370 & 1570 are the same.
And the 2470, 2670 & 2870 are the same.
Again, I think the main difference was the cc"s under the hood. I also think the rear ends were sized for the smaller ones like the 770"s /970"s / 1270"s and 2470"s and I think that caused some problems in the next sizes up.
Mikey
04-24-2006 13:15:11
 Re: case 770 in reply to Mikey, 04-23-2006 18:09:54
I should add that this is more or less true for most J.I. Case & CaseIH tractors over the years.
