Weak hydraulics 3-point on 930 Case
Kenneth H
04-22-2006 18:00:19
I"ve got a problem with my 930 Case - weak hydraulics and the hydraulic 3-point will only raise the arms, not any implements. I have been told that there is a screen in the rear end that could be plugged and could be accessed by removing the PTO shaft. Can anyone confirm that?
Grumpy
04-24-2006 05:03:34
 Re: Weak hydraulics 3-point on 930 Case in reply to Kenneth H, 04-22-2006 18:00:19
The raising poppet in the hitch valve will get sticky or dirty and will do what you say. The hitch will raise the arms but will not raise a load. There is a plate on the side of the valve. Remove this plate. There will be a load check ball and spring a lowering poppet and a raising poppet. Take these out clean them. The raising poppet has a screw inside remove this screw to get it clean inside. Install screw till it bottoms then back out 3/4 turn. Put it all back together and it should work fine. Stan
c hess
04-22-2006 18:58:41
930 COMFORT KING HAS A THROUGH WAY FILTER ON OUTSIDEOF TRANSMISSION ON LEFT SIDE UNDER PLATFORM .You need to check relief pressure . Should be 1700-1900 psi . If ok you may have leaking internal piston. Nead a gage to check pressure an if low you can shim releaf valve.Need a(i&T) manual at least as it is not good practice to guess on hydraulicks
