580C starter problem
n8xv
04-22-2006 05:05:32
Had a problem the other day with the starter not engaging the ring gear. Took the starter out and did not see any problem with either gear. Cleaned all the wire connections and put the starter back in. Now it seems to be working fine. Any ideas if I may have an upcoming problem??
Dave in OR
04-24-2006 12:00:46
 Re: 580C starter problem in reply to n8xv, 04-22-2006 05:05:32
I am replacing the flywheel ring gear on my 188D /1845 skidsteer. Which way does the ring gear go on the flywheel? Mine may have been originally installed incorrectly.
jdemaris
04-23-2006 19:06:28
That's typical when the starter-drive is going bad. You'll hear it spin and grind a little on the flywheel teeth, but not engage. Usually, at first, it's hit and miss. It will work great, then it won't, etc. Eventually, won't work at all and might also chew up your ring gear. I just changed mine yesterday on my 580CK.
