VAC what a day
jdman(MO)
04-21-2006 18:33:36
As I was merrily going to disk a garden, I was rewarded with a loud back fire, and dead tractor. A dodge truck pulled me home, where I discovered the advance in the distributor torn to pieces. I found a junk distributor and installed, but not before I was unable to find any Timing marks on the flywheel. I guessed at it and apparently got pretty close as it started right up and ran well. Have not fine tuned it yet. Had just finished trying to put a starter on a VAI, and no matter what the book says a Vac starter will not go in the hole on a VAI, unless the spring is less that 2 inches in diameter. After looking at about 20 springs I found that most were 2.125. There must be some special starter out there for VAI. Sorry for the rambling, Oh P.S. found milky stuff on top of valve cover, there is no end to this. Russ
Paul f
04-22-2006 09:19:55
 Re: VAC what a day in reply to jdman(MO), 04-21-2006 18:33:36
Joe is correct about the flywheel mark ...a chicken could have scratched a more visible mark on my flywheel!! (But it is there and I punch marked and painted mine for next time)... and why did they put the timing mark on the other side of the engine from the distributor and spark plugs????
Joe (Wa)
04-21-2006 19:18:23
There are different type timing marks on the VA series flywheels depending on model year. One thing they all have in common is being hard to spot in that little hole.
The easiest way that I have found is to connect the timing light pickup to the coil wire and rotate the distributor between near stall advance & retard until you spot the mark.
The milkly oil on the valve cover is generally just from condensation as the valve cover cools faster than the block and attacks moisture. If it is not in the crankcase oil, you are likely ok.
I've heard the same about the problem with the VAI starter installation. My Case VA parts manual only lists one starter for all. Must be something too it though as often as it comes up, Donno.
Joe
