Case Puller
Sambo
04-20-2006 18:42:18
Want to make a 930 puller and want to know if anyone has a 504 diesel for sale or what i can do to hop up the 377 gas thats in it. Thank you
Walt Davies
04-21-2006 21:53:37
 Re: Case Puller in reply to Sambo, 04-20-2006 18:42:18
By using the v series the engine is much shorter the inline would be to long to control good.
Your friend may have the 6V53 series engine it has a lot less power and the valves are not as good and have a tendisy to brake off right at the valve guides. There is a 1941 Case around here that has a 3-71 in it. It fits and look like it was made for the tractor. Thats why i think the the 6V71 would be just great plenty of power and RPM to get you down the tract.
Walt
DBoll
04-21-2006 04:47:28
504 sleeves, moline pistons , cam and 870 gas heads
Walt Davies
04-20-2006 19:53:39
If you want to win put a 6V71 GMC in it.
Walt
Sambo
04-21-2006 16:32:30
 Re: Case Puller in reply to Walt Davies, 04-20-2006 19:53:39
Do you have a tractor with on in it. What about a regular 6-71 instead of the V6, had a 6-71 in a irrigation pump and it had all the power you needed, buddy has a silver 72 V6 detroit in a semi and it's lacking some power. Also on the 504 sleeves do u use the case or moline sleeves and how good does that setup work
Lamont
04-21-2006 20:30:58
 Re: Case Puller in reply to Sambo, 04-21-2006 16:32:30
Use the Case sleeves and rods. It will work great. You'll have to make wrist pin bushings to fit the Case rods to the Moline wrist pins. The Case pins are too big. I am using brass bushings.
