dc dies
ken in indiana
04-20-2006 02:48:30
after getting the points set and the plugs replaced and overhauling the carb. the tractor will run for a while then die , but will start right back up after a few cranks . any help would be greatly apprciated. thanks.
JDB
04-20-2006 10:07:52
 Re: dc dies in reply to ken in indiana, 04-20-2006 02:48:30
Check inside the tank for anything floating. My DC did the same thing till I found a platic cap floating around in the fuel tank.
other Will
04-20-2006 04:03:30
Make sure the gas cap vent is open.
Cambted
04-20-2006 03:57:16
Check the fuel flow to the carb. Often there is crud in the tank that can slow down the fuel flow enough so the the tractor runs fine until the carb bowl empties. If that's not it try to take the carburator off and drop it into a can of carb cleaner overnight, check to see if the float has a leak, get your self a rebuild kit at NAPA. One of those options should cure it. LOL!
todd hamilton
04-20-2006 07:05:30
 Re: dc dies in reply to Cambted, 04-20-2006 03:57:16
I agree with Ted. I replaced the fuel shut-off valve and bowl on my SC just because the valve leaked and my horsepower came up 15%. I didn't think it was running poorly before the change.
